Magnetic Coupling for a Pump
I would appreciate knowing about the reliability and durability of magnetic couplings to drive a waste water pump.I have a five h.p. electric motor that will pump 100 G.P.M at 40 ft. of head. The waste water is slightly acidic and biologically contaminated. I do not want any chance of leakage thus the reason for a magnetic coupling.
RE: Magnetic Coupling for a Pump
Magnetic drive couplings are non-contact. There is nothing to fail or wear out. Most of the time the magnetic rotor that is immersed, is manufactured from 300 series stainless. The pump rotor must be fully supported, ie, bearings in your fluid. The barrier between the coupling halves must be non-magnetic and a poor electrical conduction (ie don't use aluminum, copper, silver). Barriers are usually 300 series stainless, hastelloy, berrylium copper, plastic,ceramic, or glass.
www.RimtecCorporation.com
It depends strongly on what kind of waste water it is, when there are not too many or to large solids in the fluid, no problems should be expected witd a standard bearing cartridge, the coupling is made up of non wearing parts, so the bearing will be the bottleneck.
