Tensile Testing Question
Dear All,
We currently outsource all of out tensile testing jobs. However, due to various reasons, we have been mulling the idea of bringing the work in-house. We need to perform tests per both ASTM (E8) and EN (EN10002-1 and EN10002-5) specifications on a regular basis.
I foresee problems with calibration as both these sets of American and European specifications seem to demand two differing sets of calibration requirements.
Can you all please advise me if this might be a problem in the long run? How difficult would it be to switch from one calibration standard to the other?
Any help/direction from the forum would be much appreciated.
Thanks...
Thanks...
RE: Tensile Testing Question
Thank you for your response.
The outside vendor we currently use maintains two different machines calibrated to the two standards/specifications. I extrapolated this information to draw a conclusion that they did it because of difficulties with switching between standards. Do you not believe this to be the case?
I have limited experience with using the ASTM/EN calibration standards and therefore seek your advice.
I appreciate your help.
Thanks...
If you do a lot more work in one system over the other then set up to do the major one in house and send the other one out.
Plymouth Tube
Our volume of work is actually fairly evenly divided between the two systems. Can you advise me as to where the calibration would typically be done - on site or at the load cell/extensometer manufacturer's site?
Also, do you think it might be possible to lay down a common minimum denominator and calibrate to the more stringent values from the two standards?
thanks...
Compare your most recent results to the original separation documents. Reject if unacceptable.
Plymouth Tube
thanks for your input...
Plymouth Tube
