Surface finish on carbon or glass fiber filled PEEK
Does anyone have definitive information on how smooth a surface can be achieved on the 20-30% carbon or glass fiber filled PEEK compounds? I need it for a sealing application where our current spec is 16Ra for plain PEEK. Also, I wonder if fibers could be pulled out by the machining and leave voids.
The width of the surface will be 0.205", an angled face on the end of a short tube.
RE: Surface finish on carbon or glass fiber filled PEEK
The one person I know of who may have the answer to your question is Dave Wilkinson at Piper Plastics Chandler Arizona as he deals in such high temperature filled plastics routinely.
Chris DeArmitt PhD FRSC CChem
www.phantomplastics.com
Consultant to the plastics industry
Can you explain what you mean by "perfectly wetted out"? I'm not familiar with this terminology in this context but I'm guessing it means fully encapsulated by the polymeric resin matrix.
BiPolarMoment,
2 micro-inches sounds really good for a CFR-PEEK. This Ra finish is pretty standard for orthopedic implants with metallic or ceramic bearing surfaces, but I haven't heard the same for filled PEEK. Could you point me to a paper?
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
I know that SiComp (Swedish Institute for Composites) have done some nice work on that. I have a thesis here somewhere in a moving box. Can't lay my hands on it right now though.
Unfortunately I do not have the formal study where this information came from; The information I have was from a document Invibio (Victrex) sent me when I was asking about frictional coefficients... in the document there is a statement:
"From analysis it was observed that the roughness followed by the sliding velocity and sliding velocity / roughness interaction influence on the coefficient of friction of PEEK. These factors have a reduced influence on the friction coefficient of CFR-PEEK. For carbon fiber reinforced PEEK the coefficient of friction varied from 0.08 when the Ra was 0.05µm, stress was 5 MPa and sliding velocity was 0.02m/s to 0.22 when the Ra was 0.45µm, stress was 5Mpa and sliding speed was 0.02m/s. For PEEK a change in roughness from 0.05 to 0.45 produced a change in coefficient of friction of 0.14 to 0.4. "
I can't seem to corroborate this information easily, so perhaps it's hogwash, but if you'd like to know the source I'd have to suggest you contact Invibio directly.
Dave at Piper said you "should" be able to get 16 Ra machining a properly molded part, but it might be difficult, and that compression molded stock shapes will prove more difficult. (Drat!)
Chris at Piper said that he had recently made parts from 30% carbon fiber filled PEEK compression molded tube and they got 24 to 32 by machining.
So I guess there's my answer: if 32 won't work, it will have to be lapped. Although Demon3's thought of applying epoxy might be the ultimate solution to getting a super-smooth surface, i.e., build it up slightly and re-machine or hone.
Demon3, any suggestion as to the exact epoxy formulation/type?
For a sealing application, you may be more concerned with other roughness parameters like the maximum height of profile (Rt) or Rz instead (or in addition to) Ra. Whether or not fibers pull out of the matrix may not be picked up by looking at Ra alone.
Here's also another past post that discusses finish of PEEK: h
Lastly, attached is a paper investigating CFR-PEEK for medical applications. The Ra they report for machined CFR-PEEK of 1.106 micron (44 micro-inch) is consistent with my research to date. They also report a value for injection molded surface which is better. I'll attach second, albeit older, paper taht looked at roughness parameters for PEEK with various fillers in a 2nd post.
BiPolar: I might have the paper on file that you mention. Do you know the author?
There are 3 papers mentioned in the document but I don't know that any of them are where those numbers come from:
Effect of counterface roughness and it's evolution on the wear and friction of PEEK and PEEK bonded carbon fiber composites on stainless steel, D.M. Eliot, J. Fisher, T.D. Clark, Wear 217 (1998) 288-296
Effect of carbon fiber reinforcement in the frictional behavior of PEEK in a water lubricated environment. J. Paulo Davim, N. Marques, A. Monteiro Baptista, Wear 251 (2001) 1100-1104
Effects of sliding velocity and applied load on the tribological mechanism of amorphous poly-ether-ether-ketone (PEEK), G. Zang, C. Zang, P. Nardin, W-Y. Li, H. Liao, C. Coddet, Tribology International 41(2008) 79-86.
To corroborate your 1.1 micron number I also have a [very short] presentation that was provided to me by Invibio regading their MOTIS bearing material on CoCr in a knee application: the initial roughness was 1.6 microns but after 5M cycles it had been burnished by the CoCr to 0.16 microns. I forget the specifics of "MOTIS" but I do know it's also a CFR PEEK material--just not quite the same as their normal filled grade (different fibers?).
Motis is Invibio's pitch-based CFR-PEEK with chopped fibers. They recommend this material for bearing against hard counterparts in orthopedic implants. The paper from which I think Invibio got these numbers is: Scholes & Unsworth "Pitch-based carbon-fibre-reinforced poly (ether–ether–ketone) OPTIMA assessed as a bearing material in a mobile bearing unicondylar knee joint".
It looks like tr1ntx got an answer & is satisfied with it so I'll let it be. If you want to discuss implant grade CFR-PEEK further then I suggest a new thread in the "Bioengineers other topics" forum.
