Can't move sub-assembly
Hi all,
Got a problem.
I have a model (950 parts) and one of the sub-assemblies in the model has moved, and I have absolutely no idea how it moved. I've tried retracing my steps, but unfortunately I cannot for the life of me move it back.
I have gone through all the mates, tried to find anything that would make this sub-assembly completely unmovable.  Even pressing my mouse button harder doesn't work. :)
Is there a quick and easy way to view all relations that the sub-assembly has to the main model?
All help greatly appreciated.
RE: Can't move sub-assembly
Expand the sub-assembly and open the mates in <name of assembly> folder. Any mates that the sub-assembly has in the main assembly will be there.
Jeff Mirisola, CSWP
Design Manager/Senior Designer
M9 Defense
My Blog
CorBlimeyLimey,
I'm running SW2010 SP4.
Thanks for the advice, I'll have a look at these grounding mates, hopefully this might do the trick.
JMirisola,
Thanks, I'll check it out.
Is it fixed? You might need to float it.
Hi Moon161,
Yep, fixed it. CorBlimey was right. I found the grounding mate after a major investigation. I seemed to have mated to a ref plane, then forgot all about it.
