Hysys component flowrate
This is my first post in this forum :)
I am using Hysys, and want to know the flowrate (in boths actual and standard condition volumetric flowrate) of one specific component (nitrogen) in a stream. I already have the stream fully defined. Does anyone know how i can extract this data from the stream?
RE: Hysys component flowrate
I use a different software (Winsim, www.winsim.com) and never found that kinda of problem...
This is pretty basic - maybe you should take a course?
Best regards
Morten
Best regards
Morten
The method you described would be quicker, but I couldnt find a compressibility chart for the gasses on the web. Is it possible to get a compressibility chart from Hysys for a range of pressure/temperatures in a easy way?
