Customized PAX files failing after port to win 7 64 bit OS...
This is causing NX to lock up when I try to start a new file. The dialogue never appears.
I've compared my modified PAX files to the native x64 originals and it doesnt look as if the format has changed. The headers look the same etc...
My ENV VAR path and folder structure to the custome stuff is all the same as the x32 version as well.
Is there some wrinkle in with having moved all this to the OS???
TIA Dave
