CANTILEVER RETAINING WALL KEYS
Does anyone still use keys below cantilevered retaining wall footings to resist sliding? I'm debating using one, and I've getting conflicting ideas as to where best locate it (i.e under the stem, or under the heel at the footing edge).
Thoughts/Comments? Appreciated.
RE: CANTILEVER RETAINING WALL KEYS
I believe the current trend is not to place it here for stability considerations and to place it more toward the retaining side of the wall (the heel). Then to check the stability for a (sliding) shear failure along a plain from the base of the toe to the bottom of the key, as well as a horizontal shear failure plane at the base of the key. In addition to the usual checks.
In future I will likely continue to place the key directly under the stem, use my retaining wall program to run the conventional checks and size the reinforcing and members; then run a stability program for additional checks of failure surfaces and overall stability.
However, per some other post I just made in some other forum 90% of the time it's best just to use the State Standard plan, or if the local agency has a standard retaining wall just use that one. No point on reinventing the wheel.
Mike McCann
MMC Engineering
Motto: KISS
Motivation: Don't ask
