Conical or rotated profile in sheetmetal
Using SE ST 100. Seldom use sheet metal and I cant figure out how to create conical or rotated sheet metal part. Can do it in model and import it but can it be done in sheet metal module?
RE: Conical or rotated profile in sheetmetal
The two ends of the cone will be the 2 profiles.
I would create them as sketches first, and make sure there is a break at the same point on each circle.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
If you do a square to round, its best done in quarters, so that you can map vertices correctly.
bc.
Quadro FX4600.
