Missing break in drawing.
SWX 2010 SP4, drawing has a broken view of a long tube- there are breaks in the tube to fit it on the sheet. All breaks display on the screen, one does not print out.
I've sketched the break in before when I've seen this, but it's a PIA because sketched lines disappear if they cross into the zone cropped out by the break.
Any ideas?
RE: Missing break in drawing.
Does the print preview look correct?
If yes, then it could be a printer driver problem. Are you able to test using other printers?
Nope, same prob w/ PDF, Laser print & plotter. Seems that if I sketch a line w/ endpoint coincident w/ break line, it prints the break out.
