Buckling in a plate model
I am planning an analysis of a structure consisting of steel plates welded together. I am planning to use SHELL63 elements. Some plates will be loaded with compression.
As we all know, these plates may buckle. This effect does not show in a perfectly elastic analysis.
How can I include this buckling analysis in the model?
An idea that I thought of my self is to use NLGEOM,ON option complete with some offsetting displacements on critical parts. Would this work?
Hope to get some tips...
RE: Buckling in a plate model
Hello all,
An update to above,
Indeed the solution appears in the shape as described above. The offsetting displacements are generated using an eigen-buckling analysis, fed back into the original structure with geometry update.
I don't quite understand the results yet, but it appears that as long as there are results, no buckling occurs.
Anyone else has experience in this?
Dear
The procedure you are describing is a non-lin buckling analyse. As you describe buckling in a nlgeom,on can only occur is there is a initial imperfection. This imperfection is often retrieved from the lin-buckling. But also often this is a know situation( product imperfections).
Also good to use it the stabilization command.
If your looking at the results of the non-lin buckling you should compare the same shapes!! This seams basic but very important. And keep in mind that the critical buckling load of the non-lin buckling should be less then the lin-buckling.
Dear Ansysfreak,
Thank you for your input.
I don't quite understand your differentiation between the linear buckling analysis and the non-linear analysis. I agree that the analysis that I describe with the NLGEOM,ON option is non-linear.
I multiplied my load with 30 and the solution stopped converging after 0.8 loadstep, thus giving a buckling load of 24 times the original load. This is good. It is not dependent on the amount of imperfections that I induce.
How would I perform a linear buckling analysis?
Struct
