flanges leaking during sail-away?
We're about to sail away with a converted FPSO, and as part of the pre-start-up checks we need to check a sample of flanges to determine if vessel motion has caused leaks.
Are there flanges that are particularly prone to leaks in terms of type, pressure rating, material, location (length up/down-stream, proximity to bends), fittings, etc?
M
M
RE: flanges leaking during sail-away?
"I am sure it can be done. I've seen it on the internet." BigInch's favorite client.
http://www.youtube.com/watch?v=hpiIWMWWVco
"Being GREEN isn't easy." Kermit
http://virtualpipeline.spaces.live.com
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
This is possibly because from running on HFO at 140-150degC, shut down involves switching to gas oil at ambient. Not everything cools at the same rate.... so not related to vessel movement.
JMW
www.ViscoAnalyser.com
Our internal piping specifications essentially prohibits the use of 3" and 8" class 150 flanges.
