screen protection film manufacturer
I'm looking for a source for a adhesive protective film similar to the screen protector material used on cell phones. An ideal solution would be a gray tinted hardcoat PET film with and a silicone adhesive that would allow it to be installed easily without bubbles and removed if damaged without leaving residue. Our application is to apply a gray tinted film with hardcoating to the exterior of a polycarbonate lens to block heat generation in a product when used in direct sunlight. We're looking for approx 50-60% light transmission and as much IR blocking as possible.
Any help on a source for raw material would be appreciated.
RE: screen protection film manufacturer
Dan - Owner
http://www.Hi-TecDesigns.com
Also try CS Hyde as they make lots of films and adhesive tapes based on many polymers.
To block IR tin oxide coating is commonly used. For example it's used on domestic oven doors to reflect the heat back inside. Other materials work too.
You need to reflect the IR and not absorb it. If you absorb it then that process will heat your film which is what you're trying to avoid.
Chris DeArmitt PhD FRSC CChem
www.phantomplastics.com
Consultant to the plastics industry
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
Dan, you credit me much more than is due...I too would have contacted 3M.
Harry
www.tynevalleyplastics.co.uk
I'm still digging but thanks for the help.
