Material and Treatment for Gears
Hey all.
I've designed a "gear reducing clutch" for a power window motor, like the ones typically found in vehicles. Running off the pinion gear of the motor, I have a set of 3 planetary gears that perform a reduction of 3:1, then a ring gear.
My problem is that for prototyping, the ring and planetary gears have been made from CRS1018, are were cut on our laser and are untreated. After about 3-4 hours of constant use, the planetary gears are totaly destroyed. The hole in the planetary gears are oblonged, the teeth are "crushed" to half their thickness. We have melonited the ring and planetary gears, but this does not help.
There is no wear on the ring gear or the pinion, only the planetary gears. What would be the best material and treatment method for the planetary gears? I am thinking 4330 with a heat treatment to C50-55. Any suggestions?
"The attempt and not the deed confounds us."
RE: Material and Treatment for Gears
We are also seeing the planetary gears "riding up" and "riding down" the pins they are attached to depending on the direction (CW or CCW). I don't have any room for fasteners. Any ideas how to stop this axial movement?
