Shrink fit, rookie needs help
We need to shrink fit a 210.5 mm diameter shaft into a hollow cylinder (OD 535 mm, ID 210 mm, Length 560 mm), both made of 1020 steel. Some people here are suggesting heating the cylinder and simultaneously cooling the shaft. While I can understand & calculate shrinking of the shaft if cooled, I can't quite visualize how the cylinder will behave when heated. I'm thinking may be the bore diameter will instead decrease when the body of the cylinder expands?
I guess I have to calcualte stresses but the first problem for me is whether the bore will shrink or expand & by how much.
I have very little experience in shrink fitting. Can anyone please help?
Thanks.
Thanks.
RE: Shrink fit, rookie needs help
Look through the forums and I think you'll find this topic has been asked before.
Tata
