Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...The enviroment is simple, natural and efficient. The members are competent, educated and professionals..."
Geography
rickyrobbi (Mechanical)
6 Oct 10 16:44
Hi everyone!!!!
I have a problem.
I have to grind a semisphere on a conventional grinding machine.
I use a special dresser unit to profile the wheel and i don't have any geometrical problems.
My problem is the finishing that is not very good because the grinding operation is made in plunge. I need to reach 0.2-0.3 Ra.
Can anyone help me?
thankyou in advance
Riccardo
saberblue (Industrial)
8 Oct 10 17:40
Have you confermed that the grinding wheel currently in use is capable of producting the desired finish? Will the material in it's current condition allow you to achieve the desired surface finish?
To answer these questions you will need to talk to your wheel supplier. If the basics are in place you need to work thru one or more of the many check lists.
good luck
twingrip (Mechanical)
21 Oct 10 3:20
After you have checkout what saberblue suggested you need to assess the speeds and feeds of your plunge (what type of machine, centerless or Micro-Centric). Importantly, you need to assess the speed at which you dress the grinding wheel (slower is better), use a single point diamond, how much stock are you removing before you finish, on shperical rollers your finish pass is typically .001 to .00015", you migh experiance wheel breakdown if you are taking more, in which case you can eiher dress before finishing or add a semifinish op, and check the concentration in your coolant 5-6%.
Close Box
Join Eng-Tips® Today!
Join Us             Close
