What kind of motor can move in several dimensions?
I need a part for a project I'm working on, and I can't remember what it's called. Its an electric device that has a rod coming out on one side, and what it does is to pivot the rod in any direction (left, right, front, back). What is this thing called?
RE: What kind of motor can move in several dimensions?
http
TTFN
Who knows where I can find, or atleast how to build, a spherical servo?
Cheers
Greg Locock
X-10 usually has their pan/tilt on sale, if you're sufficiently patient. If not, there's what appears to be a refurbished unit for $30: http
It comes with a video camera, which you can ditch or use for something else.
A brand new P/T system by itself runs for about $100: http://www.x10.com/products/x10_vk74a.htm
TTFN
h
See attachment. .
Thanks for all your help!
If you have time to kill, look for "rosette scanner" similar to what goes into a Stinger seeker.
TTFN
