Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...your web site's great! I've been using this system for almost a year now and find it really, really helpful. The people have been helpful in answering just about any question you post in the forums..."
Geography
saksgppl (Structural)
6 Oct 10 10:02
I have a 3D dxf file of a deformed shape geodesic structure.  The elements used to define the deformed shape are triangle shaped.  I have imported this DXF file (attached) into AUTOCAD and placed a surface onto it (quilted surface I think).
Now, I need to take that surfaced model and combine that with an INVENTOR 3D model to check for interference fit.   The problem is that when I import it into AUTOCAD INVENTOR, it requires a "thickness" to the surface to be really 3D.  INVENTOR does not permit me to enter a thickness - I beleive that the surface is not "continous" may be the source of the problem.
Anyone ever try this before and found how to get the surface into INVENTOR as a surface that I can work with ?
Thanks.
rollupswx (Mechanical)
6 Oct 10 12:35
Well, the DXF is imported as a Composite and you need as surfaces to Thicken.  You can do this through the Construction Environment - but then each triangle would have to be thickened individually.  A lot of work unless you are only interested in a certain area.
http://au.autodesk.com/?nd=class&session_id=3056
francesca (Civil/Environmental)
6 Oct 10 21:50
Can you make a mesh surface? http://www.lmgtfy.com/?q=autocad+mesh+surface
Close Box
Join Eng-Tips® Today!
Join Us             Close
