Laser drilling aspect ratio and tapering?
I'm trying to understand the aspect ratio when laser drilling. I will be using an ND Yag for drilling an entry diameter of 20 microns and I know the hole will get smaller as it drills through about 0.2mm thickness.
How can I calculate what the exit diameter will be?
Ant.
