Inertia Releief approach in static analysis
Hi All,
I couldn't understand how inertia releief approach solve the probelm without any constraints.
I have referred many documents available in Internet but i am not clear about the concept.
Can any one through some light on this.
Thanks for your time
Hanuman
IEL,India
RE: Inertia Releief approach in static analysis
i'm guessing that you are referring to applying equal and opposite loads to a model.  eg lift on the wings and tailplane and inertia reaction (weight) on all th epieces of the plane.
even if you do this, you still need to constrain the 6 degrees of rigid body motion; maybe fix one node in space (constrain x, y, z, rx, ry,rz).
