Is the CFM per ton starting rule of thumb the same on the condensing
side of the unit. I am aware of the added tonage or btu of the compressor but need a good starting point
RE: Is the CFM per ton starting rule of thumb the same on the condensing
More a function of delta-T. The heat you are transferring to the outdoor ambient air is sensible only.
