Should not AISC Table 7-7 and Table 10-1 give the same result?
Can anybody explain the huge differences between these two tables for connections with only two to three bolts? Attached is a spreadsheet that compares them:
RE: Should not AISC Table 7-7 and Table 10-1 give the same result?
There is no eccentricity taken on the instanding leg bolts for the connection you reference. That's why the tables don't provide the same values.
