Involute Spline DIn 5480 - Help!!!
I don't need if this has been answered before, but can you please tell how to calculate the min and max measurements, when you measure between to pins/balls? I have DIN 5480, parts 1, 2 and 15. In DIN 5480-2, I can find the nominal value in the tables, when you are measuring between 2 pins, but i cannot seem to find the formula to calculate to calculate the min and the max values
I have seen some earlier posts, where "gearguru" answered a similar question, but he only showed the values, not the calculations
Any help would be appreciated.
Thank you
Thank you
RE: Involute Spline DIn 5480 - Help!!!
calculations. You do have to use a pin diameter
large enough to not bottom out in the roots.
http://www
If you click "Show contents" you will see it tells you how to calculate fits and tolerances.
Can anyone tell SPECIFICALLY how to calculate the tolerances.
But thanks to dinjin and spigor for the speedy replies.
i was looking at the new standard and it turns out that if you use the old standard DIN 5480-14, it's much easier to find
http://www.gearsandbearings.com
Ron Volmershausen
Brunkerville Engineering
Newcastle Australia
http://www.aussieweb.com.au/email.aspx?id=1194181
The choice of interference, transition and clearance fits are given.
The standards even show examples of how the tolerances are calculated.
Perhaps you could show us 'exactly' which parts you are having trouble with.
Ron Volmershausen
Newcastle Australia
