profibus Control
profibus Control
Can Profibus replace the hardwired for the motor contro? As a plant operator, I haven't got convinced not to use hardwired control for start-stop of the motors, especialy for large motors.
Can somebody make some commments?
Thanks in advance.
Thanks in advance.
RE: profibus Control
If we are not speaking of Safety Systems, there are ways to implement Profibus control with a quasi-manual system that can take control if the Profibus comm signal is lost. One nice thing about Profibus is its ability to self-monitor. I use Siemens Simocode relays on large motors as the protection device and control interface. They have the ability to be controlled by a Profibus network on normal operations, but they use the network monitoring function to automatically allow for manual hard-wired control if the network ever goes down. In fact I set them up to be seamless transfer in most cases and I always program them to allow a hard wired E-stop to override any Profibus command, unless a disorderly shutdown will have worse consequences than an E-stop.
"If I had eight hours to chop down a tree, I'd spend six sharpening my axe." -- Abraham Lincoln
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
But in my opinion, ProfiBus might be better for motor controls because it is deterministic and most Ethernet TCP/IP based networks are not. An exception to that I know of is the ProfiBus version of Ethernet, called ProfiNet. They add deterministic data to the standard TCP/IP protocol packets to make it more deterministic, but most people consider it slightly less so than ProfiBus because of the inherent nature of Ehternet to start with. In sub-station automation this may not be an issue, with motor controls it might. You would have to evaluate what that means to you.
Would you consider to use Profibus to control the motor only without any hardwired control?
