Bending 3.5" O.D. pipe pile
Is it possible to make a 90 degree bend with 3.5" diameter pipe pile?
I need 2 feet longe pipe pile with 90 degree bends at the end which will be welded to a plate (will look like bike rack or so) The pipe pile is pipe #3 double extra strong per AISC table 1-14 (O.D. 3.5", I.D. 2.3").
RE: Bending 3.5" O.D. pipe pile
Steve
One source: www.ttb.com
" allow the formation of long sweep elbows from round, square and rectangular tubing up to 28" outside diameter"
The suggestion to use a standard weld elbow is a good one. You could also miter the pipe at a 45 deg angle and weld it back. This would provide a sharp 90 deg angle with no bend radius.
Can I make L-joint instead by cuting at the pipe edge 45 degrees (2 piece) then weld same making he right angle? Thanks again..
