Voltage testing medium voltage
Is there a non-contact medium voltage tester for use with a "shot gun" hot stick? I have 12470 volts at the load break elbow connections in the primaries of our pad mounted distribution transfomers. The load break elbows have an external grounding conductor, a bare solid #12, and they all parallel to the ground rod, as well as with the transformer shell and secondary grounded conductor. Do the bare grounds on the load break elbows interfere with a non-contact voltage reading?
Jimi Young - civilian
184th CES/Electrical Shop
Ks Air Nat'l Guard
McConnell AFB, KS
RE: Voltage testing medium voltage
http
http://ww
http:
http://www.dn.eng.com.au/modiewark.html
Bill
"Why not the best?"
Jimmy Carter
