PDMWorks File Ownership help
A co-worker using PDMWorks has ownership of a few files. They are checked in and up to date in the vault but he is on vacation and I do not have access to his PC password without an act of congress. I am the PDM administrator, is there a way for me to release his ownership with the PDM vault admin software so I can check these files out and assume ownership myself?
Or what would you suggest
Thamks, Tom
Thamks, Tom
RE: PDMWorks File Ownership help
If the user is not setup as a user 'and' an admin, you can't access the files.
Chris
SolidWorks 10 SP4.0
ctopher's home
SolidWorks Legion
Matt Lorono
Lorono's SolidWorks Resources & SolidWorks Legion
Adding on to fcsuper's response:
You can reset the PDM login of the user on vacation, then log into PDMWorks as that user and release ownership. Log back in as yourself and you should be able to take ownership. Obviously you need to notify the other user about what has transpired.
Eric
Matt Lorono
Make sure they're the latest verison files. He might have newer verisons on his PC that are not uploaded to the PDM vault. Just and FYI.....
Colin Fitzpatrick (aka Macduff)
Mechanical Designer
Solidworks 2010 SP 3.1
Dell 490 XP Pro SP 2
Xeon CPU 3.00 GHz 3.00 GB of RAM
nVida Quadro FX 3450 512 MB
3D Connexion-SpaceExplorer
