zooming the model versus tree
When I try to zoom, it is the tree that gets zoomed. The focus of my zoon commands is the tree and my rotate button is disabled. How do I return the focus back to model? Thanks
RE: zooming the model versus tree
This happens when you click on of the white lines in the tree structure (eg if you go to click a little plus sign but you are too low).
Two simple options;
1. Click again on a white line in the tree
2. Click the origin of the little xyz axis in the bottom right corner.
Then enjoy zooming your model again.
Tim
try also SHIFT + F3
Eric N.
