causes of sloping floors
I just looked at a first floor in a 60 year old house that is sloping, not toward the foundation walls, like you'd expect if there were settlement, but about mid-span of the joists. Looking at the joists from below, there didn't seem to be any very obvious deflection, but I suppose it might look worse from above than below.
I'm thinking the most probable cause is creep losses and under-sized joists. (They're 2x8's and an 11' span). What do you think? I've seen this once before and was kinda stumped then too. Thanks.
RE: causes of sloping floors
Could also be creep as previously mentioned.
Mike McCann
MMC Engineering
Motto: KISS
Motivation: Don't ask
