Main-Tie-Main
Main-Tie-Main
Main-Tie-Main
Is there a requirement for a 4 pole tie breaker in a Main-Tie-Main system
RE: Main-Tie-Main
No.
RE: Main-Tie-Main
At least not in the US.
David Castor
www.cvoes.com
RE: Main-Tie-Main
On the other hand the neutral is classed as a 'live' conductor and if it is not disconnected from the system then it remains a 'live' conductor so far as the safety regulations are concerned. That can make things slightly more awkward when maintaining a bus section because a 3-pole breaker does not provide a full isolation from the system.
RE: Main-Tie-Main
Based on the array of geographic, voltage, and applicable code information not included in the OP, there isn't much we can do to help.
RE: Main-Tie-Main
Next round of drinks says that he is from the US. wink
RE: Main-Tie-Main
You're undoubtedly correct.  Too many of my fellow countrymen don't seem to realize there's anything outside the US or that if there is that things might be done differently anywhere else.
