Pressure vessel for China
I need to get two pressure vessels made for use in China.
They are to be made to ASME VIII Div 2.
I know they have to have Chinese SQL.
Can anyone help with suggesting some companies to do this work.
The vessels are 316 stainless steel and weigh approx 250KG each.
Test pressure will be 60 Bar on one and 410Bar on the second.
Any help will be appreciated
RE: Pressure vessel for China
I understand that Astro Cosmos has no factory in China. However, this fabricator has Chinese Pressure Vessel License..
dbday,
Do you require fabricator in China? If yes, you may search for fabricators with ASME U2 stamp in China from http:
Petrotrim Services
