Total LPG Mass in tank
How do i go about calculating the total mass of LPG (mixture butane-propane)in a tank which contains both liquid and gas phases.
Given data are: Total tank volume, liquid level, total pressure and tank temperature.
Any input will be appreciated.
Harry
Harry
RE: Total LPG Mass in tank
http
Find the densities of propane and butane liquid at the same temperature and pressure and multiply each by the percentage in the mix.
If the level was relatively high, I'd tend to just ignore the mass of the gas phase.
"I am sure it can be done. I've seen it on the internet." BigInch's favorite client.
http://www.youtube.com/watch?v=hpiIWMWWVco
"Being GREEN isn't easy." Kermit
http://virtualpipeline.spaces.live.com
If you are after the gas and liquid compositions, then a bubble point calculation using K values may be of help.
See also thread135-111334: Propane/Butane vaporization calculation.
Or use Raoult's law since the negative deviations would be minor.
((LIQUID sggr -((temp-60) * .0015)) * 62.4 * % tank liquid level * + (100%- % liquid level) * Vapor SPGR *.0765 * Press in absolute/14.696 * 520/ temp absolute) * volume in Ft^3
What are: sggr and spgr
I see that the equation is not temp consistent. Both F and R are used. Is this correct?
Is volume (last term in equation) the tank volume?
Harry
