filtration for irrigation
I need filtration for an irrigation system supplying centre pivots @ 1500m³/hr
What type of filters could be considered for the application?
Water is abstracted from a service canal.
RE: filtration for irrigation
AMIAD has irrigation filters
As Lan123 suggests, you need to talk to the irrigation equipment supplier and determine what level of solids that the equipment can handle.
