Programmatically identify the version of NX installed on a system
Is there an easy way (via batch or script) to identify the version of NX 6 installed on a system (32 or 64 bit NX6)?
...rick...
...rick...
RE: Programmatically identify the version of NX installed on a system
While that might help you out, I'll ask around for if there's a more direct NX Open/KF call which might reveal this same information.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UF_ask_system_info()
...which will return something which you can use to identify whether you're running a 32-bit versus a 64-bit version of NX. What is reported is the Windows OS which is running but based on HOW that is worded, you can deduce what it is that you're looking for.\
For example, if this call returns a string with says something like...
Windows NT (x64)
...then you know that this is the 64-bit version of NX. However, if it returns something like...
Windows NT 6.1
...then it's the 32-bit version of NX which is running.
I know it's not completely logical, but then it IS Windows which is being asked for the information, so beggers can't be choosy
John R. Baker, P.E.
Industry Sector
Cypress, CA
Thx. But of those two answers, I'm thinking the syslog is the better of them. FYI I'm not tryong to make that determination while NX is running. I'd like to make that determination from the OS level. I need to know which systems have the 32bit NX6 on them vs the 64bit version. Our problem is that some, but not all, of our users are running 64bit Win7 are actually running the 32bit version of NX6.
I'd like to get an accutate accounting of our systems, and identify those specific cases.
I thought a batch call from everyone's login script would be easier than having everyone run an NX utility. A lot of our users run NX very infrequently. It's easy to determine OS in that circumstance, but not so w NX.
I was hoping perhaps there may be a few unique filenames in those versions, but perhaps I'll just have a little vbs or powershell script to get it from the syslog.
...rick...
John R. Baker, P.E.
Industry Sector
Cypress, CA
Please try the following command
"%UGII_BASE_DIR%\ugii\env_print.exe" -p
which will return either ix86wnt for 32-bit or x64wnt for 64-bit.
Hope this helps,
Joe
Correction: A better approach may be to use
"%UGII_BASE_DIR%\ugii\env_print.exe" NX_ARCH | findstr x86
which will set ERRORLEVEL to 0 for 32-bit or 1 for 64-bit.
Regards, Joe
Thx for taking the time Joe
...rick...
