Canadian Electrical Code for Commerical Buildings
I am currently trying to read through the CSA Electrical Code about installing receptacles for a commercial building. I do not see an area for commercial and industrial electrical requirements, however I assume they fall under the general category? I also was led to believe that there is a required distance that a receptacle must be after a previous one (ie: 10' apart), but I do not see anything along those lines. If someone could point me in the right direction of where to look or if there is even any specific codes & standards for a commercial building regarding plugs.
Thanks!
