FEA seismic results applied to COMPRESS
ANSYS FEA was used to do a sprectral analysis on a pressure vessel. The ASME Sect. VIII, Div. 1, pressure vessel calc was done with COMPRESS. However, because COMPRESS only addresses static seismic calc seismic calc was not included in the COMPRESS results.
How can the FEA results be applied to the COMPRESS results?
