Hopefully nobody is doing this.
Doing the Right Thing
By NICET Board of Governor Wade R. Abbott, SET
A strange new opportunity is making its way through the NICET community. While the face of this opportunity beams with new experiences and financial gain, lurking behind the scene is a serious ethical dilemma ready to bite.
In alarmingly increasing numbers, NICET certificants across the country are being contacted by third parties promoting "consulting opportunities" where the certificant need only allow the companies these headhunters represent to utilize their name and NICET certification information to meet the requirements of state and local laws
snip
h ttp://www. nicet.org/ newsletter /sept2010/ Ethics.cfm
snip
h
RE: Hopefully nobody is doing this.
SCARRY!
Luckily, he had enough sense and ethicalness to refuse.
He actually gained a little more respect from me.
If we all agreed, we would be Communists.- Me.
We protect life and safety. There is no way I could sleep at night knowing some carpetbagger is using my good name to do god knows what, much less that they are competent.
Essentially the equivalent of a PE plan stamping blind. For example, here in Illinois to get a State Fire Marshall Fire Equipment License or Sprinkler Contractor License you need a PE or NICET LIII employee or owner.
So there are firms who are asking NICET certificants to basically on paper be the reponsible employee without any responsibility. They are out designing, drawing permits,inspecting,etc., and the "responsible employees" are basically just getting a check and not doing or seeing anything on the project.
That is F_ _ _ing nuts. You must be stupid as a certificate holder to do so.
Having the certificate is a doorway to good pay and job security which is something that needs to be protected. As bad as things are if most any of us lost we could find something in a relative short period of time. In a week or so, a month or two at most, most of us could find something with pay two to three times minimum wage and most likely benefits.
For some the job may require a move, maybe the job might be inspecting but the point I am making is it would be a job and fact is, based upon the NICET salary survey, most of us would turn up our noses at two to three times minimum wage.
Contrast our job hunt with some you may know, some with advanced degrees, that have spent over a year looking and would be ecstatic to find a job at double minimum wage.
People rubber stamping drawings damages the value and reputation of the certification and the industry in general.
This is why I like to cold-call the NICET on my plan reviews.. just to do a quick check-see, to find out if they did what the plans and calcs show they did.
Travis Mack
MFP Design, LLC
www.mfpdesign.com
Somewhere in the country something happened. This is a warning shot across your bow by NICET and only an idiot wouldn't pay attention.
