how do you generate a hydrograph?
I was wondering what program do you use to generate a hydrograph. I just saw a hydrology report done by someone else and the person used Hydaflow Hydrographs Extension to design a detention basin. But the hydrgraph was manually input, so the engineer did not use Hydraflow to create the hydrograph. The hydrograph looked like a smooth bell curve. I think Hydraflow generates the triangular one. We use Modified Rational Method here in Southern California for smaller projects.
Do you have any idea which program was used, and where can I get it?
Thank you in advance!
RE: how do you generate a hydrograph?
http://www
Your local agency may have a specific Unit Hydrograph that is required for your location. You may want to refer to the original drainage report or standard drainage manual. I know that our state, county and city agencies all have unit hydrographs.
http://www.cpesc.org/reference/tr55.pdf
That should explain where the "bell shaped curve" hydrographs come from.
Then go here:
http:
That software is basic and right from the horse's mouth. After you understand how that stuff works, then move on to HEC-HMS or something similar.
Hydrology, Drainage Analysis, Flood Studies, and Complex Stormwater Litigation for Atlanta and the South East - http://www.campbellcivil.com
