Cut With Plane?
Cut With Plane?
Hello all,
Is there a way in an assemly to cut with a plane and then select which side to keep. Or something similar?
BB
BB
RE: Cut With Plane?
You have to use the regular sketch driven assy cut.
RE: Cut With Plane?
BB
RE: Cut With Plane?
Rob Stupplebeen
RE: Cut With Plane?
Assembly Cut aligned with plane you need to cut on.
John H. Dunten, CD
Certified Drafter
RE: Cut With Plane?
http://solidworksengineer.com/?p=120
look at 10m 10s - 10m 30s
...::SolidWorksEngineer.com::...
