Motor Identification
Need help in determining what type of motor I have. I have an idea, but want some input from someone more learned than myself. The reason I need to know is because I intend to attach a motor speed control, and some of the information I have is in conflict.
The facts:
The product is Master Flow PG1 Gable Vent (it is not the newer models nor does it use the newer replacement motor listed on their website)
Label information:
DM (Asia) limited
model#:DOW-136-0-34-XIN
UL (listing#) E193815
1050RPM
6 poles are clearly visible from the back of the motor, so I'm guessing brushless AC induction.
My conflicting information is:
1 HP=746w (%100 efficiency)
The label states 3.4 amp. I tested the motor at 3.4 amp.
My math: (V=IE) 120*3.4=408w
746/408=1.8HP
The label states 1/13HP ?!?! (misprint?? 1/3??)
Question:
1. Is there a definitatve way to determine the type of motor? (ie brushless/brushed) (AC/DC)
2. Where have I gone wrong in my calculation of the power/HP of the motor
3. What type of speed controller will I need? (frequency/pwm/rheostat?)
4. If I need to build a circuit for cost effectiveness, any good links to what I might need?
Colt
The facts:
Label information:
DM (Asia) limited
1050RPM
746/408=1.8HP
Question:
Colt
RE: Motor Identification
If it doesn't have speed control now, I'd assume it is an induction motor, so you're probably SOL in regards to a simple way to adjust the speed.
Maybe time for a new plan/project.
David Castor
www.cvoes.com
just noticed I wrote the formula wrong. P=IE. And correct me, please, if I'm wrong but 120V*3.4A yields 408watts. 1HP is equal to 746 watts. 746 divided by 408 is around 1.8. I doubt pf & eff will lower it to 1/13th HP which is around 57 watts. I have already metered the motor at 3.4A, and AC motor (if it is in fact) are qute efficient. Begging your pardon, but could you explain your V/A answer?
How can efficiency and power factor be calculated without first detemining the type of motor?
I would never assume becuse someonthing lacked a certain control that it was a device of a certain type. The device is designed to run full speed or be off, controlled by a tstat.
My soulition doesnt need to be simple, just cost effective ie if an expensive controller is required, I can build one rather than a OTS soulition.
My primary concern is motor ID. I see no reason to change any plans at this point.
This is seriously incorrect for ac circuits, unless the power factor is unity, which it won't be for this motor.
For ac circuits P = V*I*pf where pf = power factor which is the cosine of the phase angle between the current and voltage.
In addition the 1/13 hp is the motor OUTPUT power. You are trying to calculate the motor INPUT power. So the difference is the motor efficiency, which is probably horrendous for this little motor.
You can assume or not assume whatever you want. I'm just trying to offer practical advice. Feel free to purchase an adjustable frequency drive or build one from scratch, if you desire. As for cost effective - very doubtful.
Good luck.
The output vs the input power would explain the descrepancy, and if your correct would be horrendous!!
I appreciate your advice, and your time to give it. Assumptions are something I shy away from in general, and in this case could damage equipment, or worse, pose a safety hazzard.
I still await motor identification to determin if an OTS, or custom soulition is preferred. As for cost I keep bins, and bins of junk electronics for just these type of project.
Thanks for your input.
I am looking to ID THIS MOTOR, as to its design type (AC/DC/brushless/brushed)
Colt
never said it was 1/3HP, speculated 1/13 could be misprinted given that it is 3.4A @ 120V.
Sadly no one seems to focus on the main question 'what TYPE of motor is this' Which is what I REALLY need to know.
I may well end up tearing it down.
surly I can find all the formulas online I need when that has been determined. Until then, power factor and efficiency are useless and meaningless.
It could be a brushless DC MOTOR!!!
Colt
Let's see here! No commutator so its not DC and its not a universal AC motor.
Check the rotor for magnetism. If it's not magnetized, its not brushless DC, stepper, or AC.
That pretty much leaves AC induction. Count the power wires going into the motor. If there are only two, its single phase AC. If three, it's three phase AC.
Based on what's already been posted, its likely a single phase six pole AC induction motor.
As was already pointed out, you are figuring hp upside down. It's 408/746 = about .55 assuming perfect efficiency and power factor which will not be.
Given an induction motor, on 60hz power, the motor will turn 1200rpm at no-load and 1050rpm at full load. Speed loss is about linear as load changes between those two points.
Has this helped? What more do you need?
Honestly, 'assumed', and 'likely' just dont cut it. I was hoping the learned scholars on this 'electric motor forum' would have an easy way of testing. Since its already been built into a duct system, and teraing it out, tearing it down, then reassembling the entire thing will take several hours for what will seem a pitance, yet pinnacle bit of information.
I cannot procede forward with any type of motor control, be it built or bought, without knowing the properties of the device to be controlled. In the original plans there was no speed control, so the device was installed. Now it seems I will have to tear the entire device down to glean one tidbit of information. I only want to do this once, so it must be right the first time.
Thank you for pointing out I had the formula backward, though irrelevant since after I figure out the motor type I will run the numbers 20 times 7 different ways before I buy/build.
I was just trying to get a quick answer, and maybe there is none. I sincerely thank everyone for their time, effort, and suggestion. I havent meant to cause any problems.
If you have any other thoughts on an easy way to determine the SPECIFIC TYPE OF MOTOR this is ie. electrical test/circuit test, I would be more than welcome to have them.
Colt
Unfortuantely, you did not type in all the information on the motor faceplate, in your first post. In fact you left out the bits that actually answer your question!
The faceplate clearly says, it is a single phase, 60 Hz, 120 Volt, 3.4 Amp motor.
Actually, it is a common fan motor, "shaded pole" type. Offcourse, it has very low efficiency and pf.
You do not control its speed with VFD or PWM chopper. A rheostat or a dimmer would do. Energy efficiency of the motor+controller will go even lower.
Let us know how the speed control works for you.
Bill
"Why not the best?"
Jimmy Carter
I posted a pic of the label in my first post. Unfortunately, its just a teeny tiny link at the bottom which is why my second post, right under it was to bring attention that the link existed.
I am not familiar with 'shaded pole' design, and this gives me something to research, and see if the facts support the evidence.
I am truly suprised that modern motors such as these would have efficiency below %20!! If true, now it might be time to consider a new plan!! Maybe I coud rip the motor add a pully, and use a belt drive system with a different external motor? We'll see.
Thanks for all the input.
Colt
Colt
Thanks a million, you guys are great.
Colt
I understand why you might want to slow it down as I have heard one of these things running before, only once, and it was in my house. I took the cord of the thing it was so loud.
Cheap, small, efficient; pick 2.
You can change the speed of a SP motor by simple voltage reduction. Well actually you can change the TORQUE by voltage reduction which will indirectly change the speed. They are "impedance protected" motors so they will not burn up. But changing the speed that way will not actually save energy significantly, if that was your goal. If you just want speed control, go to the hardware store and by a ceiling fan speed controller, it's a dimmer that is a triac with a snubber circuit. Should cost you around $10US.
"If I had eight hours to chop down a tree, I'd spend six sharpening my axe." -- Abraham Lincoln
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
Thanks for the more verbose explantion of the consumption vs. output rating. That was one of the things that puzzled me a bit. It seemed strange that 3.4A @ 120V would have such a low HP output.
The complexity of the controller is of no concern to me, I have built more than a few MP controlled circuits. Unfortunately the base efficiency will preclude this motor from being in service for this project.
Thanks for the link. Dont know if I will need it until I get a new fan and/or motor.
Actually had to look up 'verbotten' LOL :) No worries I am a licensed and insured contractor. I do general remodeling to make a living. In addition I have a degree in electronics, and auto mechanics. Furthermore; the 'project' is a photo studio for my wife which has a building permit on file. So I think a 'homeowner DIY' is a bit of a stretch in this case.
What the fan is being used for is plenum ventilation. We built a second story on our house, the HVAC is in our first floor attic, so we installed floor vents for the second floor, so there is no ventilation ducts in the second floor celing. There is to be recessed HID lighting in the celing (plenum) and since it is a 10' celing, remote ballast is out of the question. HID lights and their ballast get very, very hot, so the plan is to vent the plenum. I got the gable vent but its loud. Being that it moves 1250 CFM, I thought if I slowed it down would cut out the noise. Little did I know in this century an electric motor would be so inefficient. The fan has to run all the time the lights are on.
So I may use the shaft and add a pully with a belt drive and a more efficient motor, or get another unit altogether. I hate to buy and install an entire air handler unit, but might have to in the end. I will do my homework on electic motors this time before I buy something, or I may go with a squirrl cage type blower. Its 'back to the drawing board' :P
Colt
