HEC-HMS Paired Data Entry
In the past when I have used HEC-HMS I have usually manually entered my paired data table data manually. For some reason when I do this the data won't stay in the table. Why is this? I have never had this problem before.
RE: HEC-HMS Paired Data Entry
You have to click on the "apply" button.
SMIAH Thank you very much! Where is the apply button? It has been a while since I have used the program.
SMIAH, Well I found that button but unfortunately when I use it all data entered into the table instantly and un-explainably disappears??!?!
http://files.engineering.com/getfile.aspx?folder=38f5d936-c4c3-48d9-bedc-c1b00b463d3a&file=Prior_to_Apply.jpg
http://files.engineering.com/getfile.aspx?folder=95c6cd69-d89b-48cb-80b7-ef15ba06a517&;file=Post_Apply.jpg
Also I can open files created in version 3.3 and they will run but no output is displayed?!?!? I get this message
http://files.engineering.com/getfile.aspx?folder=447d13ba-4957-4dca-a572-474ecce983be&file=HEC-Error_13000.jpg
 I considered deleting 3.4 and running 3.3 but for some reason I can't delete that program file folder?
Never mind I deleted 3.4 and 3.3 runs. Thanks again for the assistance.
