Help for a VME Noobie
I need to replace an old VME circuit card due to obselete parts and have no clue where to begin this design. In doing a VME board design, where would you suggest I start?
swb1
swb1
RE: Help for a VME Noobie
Dan - Owner
http://www.Hi-TecDesigns.com
If you have to ask.. You have a large uphill battle before you. It would probably be smart to spend a day searching for an off-the-shelf solution. You could save your company a year of labor by finding something that will work or can be made to work.
Keith Cress
If you want to replace the chassis as well, then probably National Instruments might a good place to start.
Caveat: both of the above are pricey, so shop around.
TTFN
If all else fails, you need to study the Motorola/Freescale 68000 bus interface first, VME is based on that.
Then you need to find datasheets on obsolete support ICs:
68230
68194
68901
Good luck.
Benta.
TTFN
