How to open NX6 part file from a directory while linked to Team Center
We just got Teamcenter installed for use with NX6. I started Teamcenter and then starting NX6 from teamcenter. I would like to open my nx6 files (located in a windows folder) into nx6 and save them into teamcenter. I do not see a folder structure link in the file open dialog to accesss local folders...only teamcenter folders are shown.
Thx
Thx
RE: How to open NX6 part file from a directory while linked to Team Center
-Import suggests that the file is foreign to the tool. Since the files are native NX, its just odd terminology. In my opinion Siemens has a habit of confusing very simple techniques this way.
-A user that is working in NX with TC may want to open a file from an os directory just to look at it (but not save it to teamcenter).
From here, you will be able to open up UG files in the OS enviroment. I understand why you would not want to open it up in TC at times, I have the same idea. For me, I want to open up files from OS at times for quick layout of a design analysis and I use UG to help find out certain design problems.
But, they are right, you might want to use TC as much as possible.
