Same part - two sizes?
Made an "A-arm" for a double wishbone front suspension part). Created it from separate parts and saved as an assembly. Since there is an upper and lower "A-arm" and the difference is the position of the mounting supports for the suspension shock, I also saved the same assembly as a part. I used the **same** part to create a new assembly, the upper and lower arm, adding the supports for the suspension shock. Again, saved as two different parts, differing only in the mounts positions. Once I placed the rod ends to the ends of the arms, (same sub-assembly), I've made a drawing. Even though the upper and lower arms are actually originating from the same part, I got a difference in their lengths. In real life that is not really measurable and far from being a problem, but the values are 290.721mm and 290.726mm respectively. That was just enough to spoil all the fun when I tried to apply the "parallel" mate after both ends were fixed with concentric mates... How can that be? Same part, every other distance is identical, yet, somehow I created two parts from the same assembly differing in just enough to get measurable difference which ruins a whole day work...?
RE: Same part - two sizes?
You didn't use mirror assembly by any chance did you?
TOP
CSWP, BSSE
www.engtran.com www.niswug.org
"Node news is good news."
