How do I get rid of this warning?
The following warnings were issued while loading.
[Location of File] - Read-only part is modified, it will not be possible to save the changes.
RE: How do I get rid of this warning?
If you are not running Teamcenter, you (or the current owner) will have to change the permissions on the file.
If the file is on a local or network drive, close the file and change the file permissions, then reopen the file.
You could also do a Save As to a new name.
Ben Loosli
Customer Defaults -> Assemblies -> General -> Miscellaneous
...and you'll find what you're looking for there.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
PLM systems are good if you have to use one, but they also come with a cost, usually very high.
Ben Loosli
Painfully
Ain't that the truth!
Doc
http://www.goodrich.com
If you have 5-10 engineers all in one area and they comunicate well, there may not be a compelling need.
If you have 5-10 engineers spread out globally, then the need to share data becomes more critical and you need to have something to tell others what each one is working on.
On the other hand, 35-50 engineers and mabufacturing people in one building may be enough to justify the expense and 'painful' experience of implementing Teamcenter or any other PLM system.
Ben Loosli
