Offline flyback input capacitor ripple current
I am doing an offline, isolated, flyback with:-
Vout = 36V
Vin = 85-265VAC
Primary Side DC Bus Electrolytic Capacitor = 68uF , 400V
(Panasonic EEUEE2G680)
Switching frequency = 58100KHz
DC Bus cap datasheet:
http:// www.panaso nic.com/in dustrial/c omponents/ pdf/ABA000 0CE113.pdf
This cap has a 515mA ripple current rating at 120Hz .....and
-a 1470mA ripple current rating at 100KHz
From simulation, I know that the ripple current in this capacitor due to the 100Hz replenishment from the full-wave-bridge is 465mA.
(at maximum load and minimum Vin)
-this is just on the safe side of the 515mA ripple current rating of this capacitor at this low frequency.
...the thing is, the ripple current from the 58.1KHz switching stage is 429mA (AC RMS)
The thing is , how do I know whether or not I am violating the capacitors overall ripple current rating?
....as you can tell, at the high and low frequencies, I am within this capacitor's ripple current rating, but surely, overall, I am above this capacitor's ripple current rating?
The simulator gives the total overall ripple current in this primary DC Bus capacitor as 623mA (AC RMS).........
-So do you know whether or not I am subjecting this capacitor to too high ripple current?
The actual ripple current in this capacitor is obviously spread over a large spectrum of frequencies and the harmonic frequencies (from 100Hz to a few 100's of KHz), and each individual current frequency will have a different dissipation factor....... In the face of such complexity, how can I calculate whether or not I am within this capacitor's ripple current rating?
Vout = 36V
Vin = 85-265VAC
http://
RE: Offline flyback input capacitor ripple current
R2 is taking 90% of it's rating and 82% of its power and could be too hot if stress more. R1 is taking 43% of it's rating or, I^2*R is 18.5% of the power rating. I don't know the model for this particular cap but, I'm guessing that this waveform you mentioned is too much for that cap.
You can put the cap on an impedance analyzer to determine the model.
Keith Cress
Just curious but, is this power supply PFC or a simple rectified bridge?
Temperature rise is really what sets ripple current limits, and capacitor life, and the expected ambient operating conditions all play a part in what may be acceptable.
There are no hard and fast rules, but measure the capacitor temperature rise, and just use your own best judgment.
The ripple current rating for an elko is always given at a particular ambient temperature, usually the highest allowed for the electrolyte (e.g. - 85C or 105C). The core temperature will typically be 5C higher than ambient when passing the rated ripple current, btw, but this is mostly of academic importance.
The upshot of this is that you can handle more ripple current at a lower ambient temperature, but whether you *ought* to or not is a different story, since the reflected ripple voltage is, of course, the ripple current times the ESR. Enter the film capacitor... the elko, with its much higher capacitance (and ESR) will easily handle the ripple from rectifying the AC mains; the film capacitor, with its vanishingly low ESR but also low capacitance, will easily handle the ripple from the flyback converter's operation, keeping it away from the elko.
Finally, what usually dictates the size of the reservoir elko in an offline SMPS is the required holdup time, or how long until regulation is lost. The usual minimum requirement is 10ms, or half a cycle at 50Hz - you may want more to allow for an orderly shutdown or to ride out minor dips and blips on the mains.
