Boiler Lower Drum Damaged (Repair?)
Some tube leaking near to the drum caused damage to the drum shell (lower drum).
The boiler rate is 100ton/h @ 24bar (220462 lbs/hr @ 348psi).
The nominal drum thickness is 31.7mm (1 1/4") and the minimum thickness at the damaged area is around 6mm (1/4") !!
What should be the recomended repair? Welding according ASME PW-40.3, or replace part of the shell?
Attached photo of the damaged region.
Kind regards,
RR79
Kind regards,
RR79
RE: Boiler Lower Drum Damaged (Repair?)
We used NBIC 1, and the boiler is operating fine since yesterday.
RR79
