AWS D.1.1. Maximum Qualified Bevel on V-Joint without backing
Acc. to AWS D.1.1 Clause 3, it is allowed to have a bevel on
Single V-joint as Figure 3.4- "Prequalified CJP Groove Welded Joint Details"
Limitations are for FCAW welding max groove angle 60 degrees +10 - 0.
However, can i Qualify a joint type 80 degrees as for Clause 4 'Part B-Welding Procedure Specification.
Customer told me that i have to pass the code requirments of clause 3.
RE: AWS D.1.1. Maximum Qualified Bevel on V-Joint without backing
I don't see why the customer would find this problematic, given that an increase in groove angle is not an essential variable.
Best regards - Al
I am not so involved with AWS D.1.1 here in Europe often EN-ISO 15614-1 is involved.
I found value after long search that a prequalified WPS(Clause 3) or a WPS that is Qualfied by WPQR (Clause 4)has to deal with eighter Table 4.5 (essential variables) and for Clause 4 including Table 4.6, if CVN testing is applicable
This is always involved for our customers related to offshore constructions.
Table 4.5 describes that for Groove Angle limitation is (AWS D.1.1 2010 page 144 33)A change exeeding the tolerances of 3.12,3.13,3.13.5, 5.22.4.1, 5.22.4.2.
does this mean, that on level of Clause 4, if i do WPQR testing with a 1G position, C.J.P 70 degrees bevel, i am only qualfied for this joint limitation regarding maximum limitation groove angle?
Can somebody advise me how to interpretate the rules about prequaliefied variables, and clause 4, WPS testing?
Thanks greatfull!!
As the guys have noted above they are two different sections of the code.
If you are using a prequalified WPS your essential variables are Figure 3.4 and Table 3.7.
If you are qualifying your WPS by testing your essential variables are listed in Tables 4.5 or 4.6, whichever is applicable.
Hope that helps,
Kiwi
I only have a copy of AWS 2004 so not sure if it has changed but the note you mention in Table 4.5 is only applicable to a decrease in the groove angle, not increase.
If you qualified at 70 degrees you can increase to 80 but you can't decrease to 60 degrees,
Kiwi
If the joint detail you qualify passes all the requisite tests per Clause 4 parts A and B, you not are only limited to the joint detail you have qualified, but you are also qualified to weld any of the prequalified joint details depicted in Figures 3.3 and 3.4.
The process of qualifying a welding procedure specification is simply a demonstration that the procedure you propose to use in production will produce sound welds that meet the minimum mechanical properties specified by the applicable welding standard. In this case AWS D1.1.
Good luck,
Best regards - Al
Than my range of qualification is 10 degrees increase Maximum, and i am already qualfied acc to figure 3.3 (PJP groove) and figure 3.4 (CJP groove welds on backing)with the range of this figures.
For the joint change acc to table 4.5 (31) (a change in groove type needs re-qualfication exept if this is acc to 3.12 and 3.13) is not allowed.
Do i understand well now?
If you qualify a welding procedure in accordance with Clause 4, Parts A and B, you need to comply with Table 4.5. If notch toughness is a requirement, Part D also applies.`The additional (in addition to Table 4.5) constraints of Table 4.6 come into play. I do not see any restriction in Table 4.6 that would disallow the use of one of the prequalified joint details included in Figures 3.3 (PJP) or 3.4 (CJP).
Best regards - Al
