Caterpiller D349 voltage regulator replacement
We have a Caterpillar D349 backup diesel generator set that's in need of a new voltage regulator replacement. The OEM is no longer supporting this equipment. The following is the data on the generator Model #:SRCR, Generator Frame: 687, Excitation Voltage:135V @ 71A, 1800 RPM, Generator P/N:8L10, S/N:600TH3177, 750KW, 938KVA, 0.8PF, 3 Phase, 10 wires and a standby unit. Do any one know where i can get a replacement part for this equipment. Thank you in advance for your help
RE: Caterpiller D349 voltage regulator replacement
http://www.power-tronics.com/
Hope that helps,
Mike L.
