How to remove Registry Entries
I was trying to re-install SolidWorks 2010 on a Windows XP machine. I did a complete uninstall of SW, but the registry entries are still there. I tried to delete the following "HKEY_Local_Machine\Software\Solidworks", and I couldn't.
I was following the instructions as per the FAQ
"http://www.eng-tips.com/faqs.cfm?fid=488"
Any suggestions,
RE: How to remove Registry Entries
Do you have priveleges on your computer to edit the registry?  Many IT departments lock you out of doing registry edits.
The delete key is all that is needed.
Cheers,
Anna Wood
Core i7 EE965, FirePro V8700, 12 Gb RAM, OCZ Vertex 120 Gb SSD, Dell 3008WFP 30" Monitor
SW2010 SP2.1, Windows 7 x64
http://www.solidmuse.com
http://www.phxswug.com
Check these posts on same topic (helpful while installing/uninstalling SolidWorks). But as Anna said, you must have rights to delete registry keys.
https://forum.solidworks.com/docs/DOC-1014 (a detailed document on installing/uninstalling SolidWorks)
https://forum.solidworks.com/message/133724#133724
https://forum.solidworks.com/message/146552#146552
(contains some helpful tools/exe files for installing/uninstalling SolidWorks)
Deepak Gupta
SW 2009 SP4.1 & 2007 SP5.0
MathCAD 14.0
Boxer's Blog
