Spring failure
Spring failure
I have a compression spring failure issue that I hope someone can help me with. I've tried the same spring from 2 different manufacturers. Danly #9-1610-26 and Ready Technologies #9-1610-H. Chrome-vanadium springs. Sometimes the springs break at the first full coil and sometimes they break 2 to 3 coils from the end.
The spring parameters are as follows:
OD = 1"
ID = ½"
Free length = 2.5"
Pre-load = .087"
Deflection = .512" (cannot be changed)
Total deflection = .598" (23.9% of free length)
Spring rate = 691 lbs/inch
Pressure at full compression = 413 lbs.
Application:
Progressive stamping die running at 1,100 strokes per minute. The spring is guided on the inside diameter by a ½" diameter shoulder bolt.
The problems is that we've had springs break after 300,000 strokes while others have lasted up to 4.6 million strokes. The goal is for the springs to last 10 million strokes without failure. Is there a way to calculate the life of these springs? Would reducing the percentage of free length to approximately 20% increase the life of these springs? Is so, by how much? Would a longer spring with larger diameter and a lower percentage of free length last longer? Is there a better spring material for this application? Any help will be appreciated.
OD = 1"
ID = ½"
Free length = 2.5"
Pre-load = .087"
Application:
RE: Spring failure
RE: Spring failure
There may be tooling marks, scratches, excessive decarb etc. involved in the fracture cause. Can't procedd any further without this information, in my opinion.
Alsip
RE: Spring failure
Two things gave us problems you might want to check.
Our short run spring failures were traced to essentially two things. One was not enough preload and the springs were subject to shock loading. I can't find out how this was resolved, either increasing the preload on the existing sdpring or a long spring preloaded more. The second part of the problem was at times we were changing to a lighter duty spring than what was originally evaluated and specified.
RE: Spring failure
